eximo
PC Specification: AMD 955, ati 5770, Windows 7
Hotkey request
Wed Aug 15, 2012 3:08 pm
Hi! When will you add a possibility to use a Ctrl button as a hotkey for microphone
recording during video recording. I use Ctrl button for push to talk in TeamSpeak 3.
I want to record my voice when i talking on TS3 and use a same button. Thanks!
Re: Hotkey request
Mon Aug 27, 2012 11:58 am
CTRL and ALT key are excluded from hotkey list because that may cause conflicts in some applications and games.
kuzyn007
PC Specification: Windows 7
Re: Hotkey request
Wed Sep 19, 2012 10:40 pm
radi wrote:CTRL and ALT key are excluded from hotkey list because that may cause conflicts in some applications and games.
I understand hotkey can cause some conflict but some ppl want to config buttons anyway. Is there any way to hotkey MOUSE3? I cant find any file where hotkeys are saved.
I tried to use many video record applications and i havent problem to bind mouse buttons. I start to like Action and Im thinking about buy the license so i want to find the way to bind my mouse hotkey to use teamspeak 3 in the same time.
Re: Hotkey request
Thu Sep 20, 2012 9:21 am
Additional mouse hotkeys will be added in future versions.
Blutaar666
PC Specification: Phenom X4 955, Nvidia 570GTX, Win 7
Re: Hotkey request
Sun Sep 23, 2012 11:29 am
Depending on the application you want to record a small autohotkey script could be transitional solution. It wont work for most punk buster protected games.
a possible script would look like this:
Code: Select all
MButton:: ; by pressing the mouse wheel F8 will be pressed
F8
return
