Action! 1.9.0 & 1.9.1 & 1.9.2
Fri Aug 17, 2012 10:02 pm
We are happy to announce that new Action! 1.9.0 is now available for download:
Action! 1.9.0 introduces new feature which allows to add custom logo
and other graphics to your video recordings.
Full change list:
* NEW FEATURE: Adding custom logo and other overlay graphics for video recordings
* Windows Media Player (and other players using EVR) recording fixed
* Windows multi-user improvements for desktop recording
* Stability fixes (closing Action! application)
* Small GUI improvements ("Close" option added in tray mode, recording and pause icons added for tray mode)
daniel44
Re: Action! 1.9.0
Fri Aug 17, 2012 10:54 pm
hi :)
thanks for the new version already!
will you add a multi rendering option?
this is really important to me because i need to render 5 videos almost every day, and each video takes 40 minutes (that means 3 hours that i can't use my computer because the rendering takes almost 100% power from my processor.
i forgot, can you please add the option to put the system sound and the microphone volume on different precent?
if i put the system volume to 50 the microphone is automaticly set the 50 but i want the microphone to be on 100%.
if both of the system sound and the microphone volume are on 50% the video is really quiet that it should be.
also can you please answer here?:
http://www.mirillis.com/forum/viewtopic ... 36&t=14490
and here?:
http://www.mirillis.com/forum/viewtopic ... 36&t=14493
ObserverJLin
Re: Action! 1.9.0
Fri Aug 17, 2012 11:41 pm
What is * NEW FEATURE: Adding custom logo and other overlay graphics for video recordings? How does it work?
vivan
Re: Action! 1.9.0
Sat Aug 18, 2012 5:07 am
You can choose picture to be burned into recorded video. E.g. :D
PS Vita, Nokia N8
Tash_Riser
PC Specification: Intel Core i5, GeForce GT 240, Win 7 64b
Re: Action! 1.9.0- ISSUE REPORT
Sat Aug 18, 2012 12:06 pm
I found an issue on cancelling exporting videos. When I am asked to be sure in cancelling it, it doesn't show the botton "OK" or "Cancel" anymore, only an empty area where I suppose it should be. But if I press "Enter" on keyboard, the exporting is cancelled.
I think it's an error of this new version of Action! One day before of the release date of version 1.9 I used this tool and it looked like working properly.
daniel44
Re: Action! 1.9.0
Sat Aug 18, 2012 12:34 pm
vivan wrote:You can choose picture to be burned into recorded video. E.g. :D
can you put the picture to a video that you already recorded? (if i recorded a video in version 1.8.0 can i put the picture on that video?)/
KuKiii9
PC Specification: Acer 7750g
Re: Action! 1.9.0
Sat Aug 18, 2012 4:21 pm
Yeah ! Please add this option... I hate to click, each video separately.
Scortech
PC Specification: i7 4790k @ 4 Ghz, GeforGTX 980,Windows 7
Re: Action! 1.9.0
Sun Aug 19, 2012 8:39 am
Overlay graphics
How can I add a photo/logo without a thin ugly white line around my logo?
When I make a logo I want to use in my videos I get a thin white line around my logo.
Mon Aug 20, 2012 7:41 am
Tash_Riser wrote:I found an issue on cancelling exporting videos. When I am asked to be sure in cancelling it, it doesn't show the botton "OK" or "Cancel" anymore, only an empty area where I suppose it should be. But if I press "Enter" on keyboard, the exporting is cancelled.
Thank you for reporting problem, we will take a look into this.
daniel44 wrote:can you put the picture to a video that you already recorded? (if i recorded a video in version 1.8.0 can i put the picture on that video?)/
We recommend to use a video editor to do this but there is a way... You need to playback recording made with older version and record it with new version. In example run Action!, start playback of old recording in fullscreen or window in Action! player and use active desktop or region desktop to record it with "use overlay graphics" option selected.
KuKiii9 wrote:
daniel44 wrote: will you add a multi rendering option?
This is included in plans for future versions, but we do not expect it to be avialable in near future.
Maybe in Action! 2.0 but at the moment we have no release date for this defined.
Scortech wrote:Overlay graphics
Can you please show us a screenshot? Do you use PNG graphics?
Can you please check if with this png you will also have a problem:
http://www.mirillis.com/files/temp/Acti ... 55x155.png
daniel44
Mon Aug 20, 2012 9:31 am
thanks for the answer :)
please can you help me here?:
http://www.mirillis.com/forum/viewtopic ... 938#p20938
and here?:
