kerb
PC Specification: Intel Pentium D 3GHz, Vista SP2
.Mov files video not playing after windows update
Sat Aug 18, 2012 12:00 pm
Hey, today I installed the latest windows updates (which all seem to be security updates) and then tried to play a .MOV file that worked fine last night and it just shows a green screen with the audio playing like normal, then the program stops responding after 30 seconds or so.
I tried re-installing and then tried using DivX player, which worked but didn't play as smoothly as splash usually does.
Any suggestions?
Thanks.
EDIT: I've just realised that youtube and other videos in the browser (firefox and ie) now also have this same problem.
Re: .Mov files video not playing after windows update
Mon Aug 27, 2012 11:56 am
Can you check if the video is encoded in 10bit?
