NickNorth
PC Specification: Windows 7
Problems with subtitles and auto-play
Wed May 11, 2011 11:39 pm
First, with subtitles. In .mkv files, gibberish often comes up on the screen when, I believe, the text is supposed to be placed somewhere else on the screen, rather than in the normal area in the middle near the bottom of the video. For example, if the word Splash is supposed to be placed in another part of the video, it will instead come up in the normal subtitle area as something like:
3634232{{{r9888ffkj90Splash:3284r39483hj4
And with auto-play, I click the boxes to enable it, but it never automatically plays the next file in the playlist. It just restarts the one that was just on, and I have to press next manually.
Any help?
Re: Problems with subtitles and auto-play
Thu Jul 21, 2011 10:19 pm
With auto-play problem - please disable loop option, press L or click the loop icon on the right bottom side of control pannel.
Is it possible to share us a sample of video with problematic subtitles?
We can provide ftp server to upload larger files if required.
You can also send samples to support@mirillis.com
