Stevetastic
PC Specification: i5 3.4ghz, NVIDIA GTX670, Win 7
Audio Desyncing in Games and Applications Mode
Tue Aug 21, 2012 1:33 am
While recording Battlefield 3, in "Games and Applications" mode, audio is synchronised with the video at the start but gradually desynchronises with video more and more over time. Has anyone come up against this problem and, more importantly, does anyone know of a fix for this issue?
System Specs:
Windows 7 Ultimate
Processor Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
Memory (RAM) 8.00 GB
Graphics NVIDIA GeForce GTX 670
Gaming graphics 4095 MB Total available graphics memory
Re: Audio Desyncing in Games and Applications Mode
Wed Aug 22, 2012 11:04 am
This was previous versions problem. Do you use latest Action! version (1.9.1)?
Stevetastic
Thu Aug 23, 2012 1:25 pm
Yes. Infact it only seemed to occur after I upgraded.
I'm about to uninstall out of frustration. I almost bought this program.
Sat Aug 25, 2012 8:41 am
How long do you need to record to see the audio/video desync? And can you estimate a difference in seconds or miliseconds?
We have run about 12h tests (also with bf) with perfect a/v sync as a result.
Did you try to export recording to see if it is desynced in exported file too?
What software do you use for recording playback?
Can you provide us your video recording tab settings?
Stevetastic
Sat Aug 25, 2012 11:26 pm
The desync begins roughly 5 minutes in and it's the game sound that suffers. The difference gets progressively worse over time so what starts out as a 1 second difference at 5 minutes into the video will turn into a 3 seconds difference 20 minutes into the video.
I believe I exported it, I can't remember. I'll do another test recording and make sure I export this time.
I use Media Player Classic v1.6.3.5818 (2320902) to play back video. I also run the exported video through FFMPEG to make sure it doesn't crash Adobe Premiere before importing it into that. I should note that FFMPEG has never created this issue on any other videos.
My settings:
http://i.imgur.com/8Mv17.jpg
Stevetastic
Sun Aug 26, 2012 7:44 pm
I did another test recording and uploaded it for you guys.
http://youtu.be/hNjXvtp5OgE
Stevetastic
Thu Aug 30, 2012 6:19 pm
Looks like I'll be sticking with FRAPS then.
Fri Aug 31, 2012 11:05 pm
Do you experience this a/v sync problem with all games or only with bf3?
We are investigating this but cannot reproduce problem in our labs so far.
Will keep this thread updated if we have any news about problem.
Stevetastic
Tue Sep 04, 2012 3:56 am
I'm afraid I haven't tried it with anything else. I don't need it with anything else.
Miguel
Mon Sep 10, 2012 7:35 am
I got some desync audio too while recording Trine 2 for my website, it happens also in other games, but in this one it's more noticeable as I recorded files of 20 minutes.
It seems synchronized while playing the Action! AVI files, but when I encode it with AviSynth scripts in VirtualDub, it gets delayed (500ms) at start and synchronized at the end.
Maybe it is tied to the playback codec reporting wrong timecodes or frequencies for the audio ?
I'll try some audio export to compare it to the original AVI file.
