Ikeys93
PC Specification: windows 7, Dual core 2.95, Ati 6770
Rendering
Tue Aug 21, 2012 12:41 pm
It should be awesome if we can put a rendering queue to let the program render (for example) all night 8-)
I´d love if this could be in the next version ;)
What dou you think about it?
Re: Rendering
Mon Aug 27, 2012 11:54 am
Thanks for suggesting this feature, we will add it to our wishlist and see what we can do.
Kashimus
PC Specification: windows 7 ultimate x64
Re: Rendering
Tue Aug 28, 2012 9:56 am
I would add few other options, splitting option like split at every 30 mins user can set the amount of time, or at a given file size same user can set it in mb/gigabyte.
And maybe for recording not just time limit but for file size limit should be added to.
For the rendering quese each of the videos could set the output resolution,video bitrate, and all the options or for all at once,or for each of them individually,and you could make your own settings customized preset, which you can be saved and later you need only to load that
Pause option to exporting/rendering not only stop.
Users browsing this forum: No registered users and 43 guests
