Incalex
PC Specification: Windows 7 (x64) - GTX 570 - i5 2500K
Dark Souls with DSFix (Resolution)
Sun Aug 26, 2012 1:32 pm
The Dark Souls port for PC has a fixed rendering resolution of 1024x720.
Someone released a fix to unlock the internal rendering resolution, who allow to play in real 1920x1080.
What is it?
It's an interception d3d9.dll that you place in the same folder as the game executable. It intercepts the game's calls to the DirectX 9 API and changes them as necessary to enable a higher internal rendering resolution.
The problem is, because it intercepts the DX9 API, Action doesn't detects the game (imo, because the same problem happen when you use the FXAA Injector in BF3).
Could you add support to this mod because Dark Souls is a good game, and without this mod, it's bad ...
Link : http://www.neogaf.com/forum/showthread.php?t=488240
Re: Dark Souls with DSFix (Resolution)
Mon Aug 27, 2012 11:31 am
We are working on these graphic mods support.
