CMay
PC Specification: q6600@3.0, 4gb ddr 800, gtx275, w7x64
Some Action! 1.9.1.0 Feedback
Thu Aug 30, 2012 9:48 pm
Bug:
  • It's possible for a thumbnail to have the wrong filename/label listed under it. I've not been able to reproduce it, but it was not strictly a visual error, as you could click on the text and try to rename it. It occurred after I deleted a bunch of videos within the Action! interface, and some of the videos that were further down ended up with the wrong text label. This could result in accidentally deleting or renaming the wrong recording.
Request:
  • Allow recording at framerates below 15, like 7, 5, 4, 3, 2, 1 as it would be useful for recording timelapse videos. It's OK if the framerate of the actual video is still 15 frames per second, so long as most of those frames are empty deltas maintaining the same image resulting in a smaller file. A 6 hour recording was 55GB (which is really good), but it could have been 4-10GB and given me the same results after it was sped up into 2 minutes of video. As Action! already supports setting recording duration, this would make it amazing for timelapses.
Thanks.
Re: Some Action! 1.9.1.0 Feedback
Thu Sep 20, 2012 9:32 am
Thanks for the detailed feedback!
