Dahnark
PC Specification: I7 3770k GTX 670 Windows 7 64Bits
Go back with Delete all
Tue Sep 04, 2012 8:07 am
I have deleted a lot of videos but not appear in recycle bin... what can I do?
Alexcho
PC Specification: ATI Radeon, WIndows 8
Re: Go back with Delete all
Tue Sep 04, 2012 8:34 am
Try with Racuva to rescue them.
Dahnark
Tue Sep 04, 2012 8:51 am
Alexcho wrote:Try with Racuva to rescue them.
I used recoverymyfiles... and recovery a part of them... its something
one question, is possible disable delete all files option in any .cfg archive?? I push it sometimes when I dont want... really is not good that not send to bin because its icon is a X, its say, I see it and I think that it is for delete, no delete all...
sorry for my english but I am spanish
Wed Sep 05, 2012 9:49 am
Dahnark wrote:I have deleted a lot of videos but not appear in recycle bin... what can I do?
Action! cannot put deleted files in your Recycle Bin, that's why you are asked in pop-up window if you are sure that you want to delete your videos permanently.
cwir
PC Specification: Fast one
Wed Sep 05, 2012 2:23 pm
I just did the same thing :x . I selected a couple of files and clicked the X. Ok, I admit I should have read the popup precisely (I thought I was confirming to delete all selected files). But come on.. Who puts "delete all" button and not just "delete selected".. I just lost about 1TB of video files which were like 3 weeks worth of recordings of my Battlefield 3 games which I was about to edit... I'm trying to recover them but so far I only recovered one small file.
Clearly I'm not the only one who found this to be an issue so go ahead, take the feedback and get rid of that stupid button..
Thu Sep 06, 2012 9:46 am
We are going to remove the "Delete all" button in next version due too much confusion.
CemixV
PC Specification: Windows 7
Thu Nov 13, 2014 9:54 pm
Is there still any plans to remove the delete all button at this point?
Radi said in 2012 that it would be removed, and it's still there. The fact that it asks you before hand should not matter, because it does that for both the deletion of individual files, as well as the grouped and "delete all" options. The fact alone that it's placed where any other program would place the "delete selected" option is confusing enough, and nobody's going to want to read through every time they accidentally hit record, and just want to rid themselves of the scrap file.
I've lost hours upon hours of files at this point, and even though I love every other feature of this program, the fact that I can't be sure if the time spent will accumulate to anything at the end of a recording session is leaving me wanting to hunt for a different piece of recording software.
tempusdigital
PC Specification: wqindows 8.1 pro 64 bit, geforce gtx 690
Tue Jan 13, 2015 8:19 pm
We are in 2015 and it seems that Mirillis is not considering going back with this despicable option.
I just got a new mouse, and it is not well calibrated and I am not used to it yet.
I clicked by mistake, since it moves faster than my old mouse, and voila! all my work to the sewer....
Please erase, eliminate, terminate, destroy, erase this dreadful and, from my point of view, utterly useless option.
Sure you say there is a confirmation screen, but in my case, I thought I was erasing ONE video, which I believe requires that confirmation screen as well.
It is easy enough to click the different videos you want to erase if you want to erase more than one.
Thank you, and excuse the rant, but soooo many hours of work just went down the drain. Not to mention that they are irreplaceable, for they have random characteristics I cannot duplicate.
Blaze4330
Sat May 16, 2015 4:21 pm
I was deleting a junk video when I accidentally hit the "Delete all files" button, and had 2 weeks worth a recording on it. :cry: Is there any way I can get these videos back
Mon May 18, 2015 7:56 pm
Blaze4330 wrote:I was deleting a junk video when I accidentally hit the "Delete all files" button, and had 2 weeks worth a recording on it. :cry: Is there any way I can get these videos back
Unfortunately no, however this option has been removed in one of the recent versions.
