hln
PC Specification: MacBook Pro, thunderbolt, ZBox AD03 HTPC
Crystal HD BCM970015 renders garbage on screen
Wed May 18, 2011 12:01 pm
Just bought the Broadcom Hardware Decoder BCM970015 and installed the latest driver release version 3.5.0 and Splash EX renders small horizontal lines for VC-1 BD rips. The audio is fine. The non VC-1 files play just fine. Basically, the video is garbage and unwatchable.
Also that there is no option to pick and choose my ATI video card "OR" the Crystal HD. Splash EX just uses the Crystal HD card.
I have the new Zbox AD03 HTPC and thought maybe this new card will enhance but it made it worse. Any ideas or advice? Any one?
Re: Crystal HD BCM970015 renders garbage on screen
Thu Jul 21, 2011 10:21 pm
Hi, and thanks for a feedback about Crystal HD.
Can you provide screenshots of VC-1 corrupted playback?
Do you experience this problems also with latest 1.10 version?
Please check what is the framerate fo this vc-1 videos (press "i" to show info panel).
We can playback VC-1 videos without problem on our PCs with Crystal HD.
Cystal HD is selected automatically when it is detected in the system.
We will add this problem to our todo list.
