specter
PC Specification: windows 7 64bit, AMD CPU Nvidia GTX580
export getting C runtime error
Wed May 18, 2011 6:39 pm
Version 1.7.0 worked fine for me but now using version 1.7.1 I get a runtime error when I try to export an mp4 video file. I am testing the same file that I was able to export in 1.7.0. If i turn of CUDA it will go to 100% complete but when I check the file it is zero bytes. When i turn on CUDA it get to about 76% and then gets the C++ runtime error that says the program terminated incorrectly.
Has anyone else had this problem?
I have reinstalled all of my C++ runtime libraries and installed a new nvidia driver but still get the same error.
I am using windows 7 64bit.
specter
Re: export getting C runtime error
Mon May 23, 2011 4:37 pm
Mirillis tech support recommended pressing stop on the video before exporting.
I was loading the video file and pressing pause and then going to EXPORT. That used to work in 1.7.0 but not in 1.7.1.
So if you get that error, just press stop on the video before going to the export tab or load the file directly in the export window. It works great that way.
