Tarik
PC Specification: Intel i3 HD graohics, windows 7
Picture2 on dual core??
Fri Sep 07, 2012 9:31 am
first much appreciation for the work you do to make splash pro best software i ever installed,
here's my question: i have intel HD Graphics (core i3) which is dual core i believe, and 3.20 ghz cpu
since motion2 is not recommended for under quad core cpus, when i enable it on my dual core i3 will I get the same quality result ?
thx in advance :)
vivan
Re: Picture2 on dual core??
Sat Sep 08, 2012 11:08 am
Quality is the same with any cpu/gpu.
The only difference is CPU performance, it just could be too slow for realtime frame interpolation.
So it either working perfectly or noticeably lagging.
Also quadcore recommended only for Motion² Ultra 1080p (if this option is unchecked, than all videos would be downscaled to 720p resolution before interpolation), however that statement was made 1,5 years ago, modern dualcores are fast enough and Motion² perfomance was also improved. So even my mobile i5 (i5-2410M = 2 cores (+HT) @ 2,9Ghz) is enough for it (with less than 50% cpu load!).
PS Vita, Nokia N8
Kimberlysnider
PC Specification: CPU model
Sat Oct 05, 2024 9:10 am
All CPUs and GPUs have the same quality. The CPU performance is the sole distinction; it can be too sluggish for real-time frame interpolation. Thus, it is either operating flawlessly or lagging substantially.
funsilvers
PC Specification: Windows 10
Thu Nov 27, 2025 4:58 am
Great info! I'm wondering about the impact of Motion2 on dual-core i3 systems as well. Will enabling it actually hinder performance despite potentially improved quality? I'm really trying to optimize my Splash Pro experience. Thinking about hitting the slopes with Snow Rider after this!
thomast
PC Specification: Windows 10 64-bit
Fri Jan 30, 2026 2:56 am
Hi there!
Thank you for your kind words about Splash Pro! Regarding your question:
Enabling Motion2 on a dual-core i3 CPU may not yield the same quality results as on a quad-core CPU. While you can enable it, the performance may be limited due to the lower processing power and fewer cores. You might experience slower rendering times or potential stuttering during playback, especially with high-resolution content.
If you find that performance is lacking, consider adjusting your settings or disabling Motion2 for smoother playback.
Return to “Picture²”
Users browsing this forum: No registered users and 0 guests
