Action! 1.10.0
Sun Sep 09, 2012 5:50 pm
We are happy to announce that new Action! 1.10.0 is now available for download:
Full change list:
* Important fix for recording Windows 8 Modern UI Style applications
* Added option to record microphone into separate audio track (for video recordings)
* Added settings to select microphone input audio device
* Added settings to select system sound input audio device
* Fixed audio recording at 192kHz sampling frequency
* Small GUI improvements
* Stability improvements
IMPORTANT NOTICE:
Please note that in some Windows 8 Modern UI apps Action! HUD may be not visible, however video recording
will work fine. This is a technical problem we are working on and hope to fix in the future.
We also decided to remove "Delete all recordings button" as many users reported accidental deleting all recordings.
Delete all recordings is still available from right mouse button menu.
daniel44
Re: Action! 1.10.0
Sun Sep 09, 2012 6:10 pm
Ghost wrote:We are happy to announce that new Action! 1.10.0 is now available for download:
Full change list:
IMPORTANT NOTICE:
can you add the option to record the microphone seperately from the system sound?
keep up the good job!
olyteddy
PC Specification: i7 2600, Intel HD2000, W7 Ultimate
Re: Action! 1.10.0
Mon Sep 10, 2012 2:07 am
Full change list:
IMPORTANT NOTICE:
daniel44
Re: Action! 1.10.0
Mon Sep 10, 2012 11:27 am
Full change list:
IMPORTANT NOTICE:
1. you can now tune up only the microphone volume or the game separately.
this option means that instead of one sound track that include the game sound+the microphone sound you will have a second soundtrack for the microphone only so you can change it as you like.
2. you can choose a different microphone to record with (if you have a microphone in your camera and a microphone in your headphones you can choose between them.
vivan
Re: Action! 1.10.0
Mon Sep 10, 2012 2:03 pm
Stop overquoting!
daniel44 wrote:1. you can now tune up only the microphone volume or the game separately.
If you chose to record microphone sound separately you will have 2 audio streams in one file - one with game sound and one with sound from microphone.
So, what exactly do you want?
daniel44 wrote:2. you can choose a different microphone to record with (if you have a microphone in your camera and a microphone in your headphones you can choose between them.
Yes, that is exactly what option "select microphone input audio device" for.
PS Vita, Nokia N8
daniel44
Re: Action! 1.10.0
Mon Sep 10, 2012 6:36 pm
i want to be able to record both of the microphone and the system sound seperately.
right now when you have the microphone volume on 55% the system sound is atumatically 45%.
i want to have the microphone volume on 100% and the system sound on 70%.
like that the video will be fine but right now the microphone volume doesn't match the system volume and the volume of the entire video is a lot weaker than it should be.
if i will tune up my microphone volume in a software like sony vegas the microphone will be distorted.
nmalevic
PC Specification: Intel i5-2500K, AMD Radeon 6970
Re: Action! 1.10.0
Mon Sep 10, 2012 6:53 pm
Please, add to the program for video hardware decoding support AMD! :!:
Now you only support CUDA and Intel :(
vivan
Re: Action! 1.10.0
Mon Sep 10, 2012 8:02 pm
daniel44 wrote:i want to be able to record both of the microphone and the system sound seperately.
Then use option "Record microphone into separte track" and you will get video with two indepedent audio streams: one is system sound, second is microphone...
daniel44 wrote:right now when you have the microphone volume on 55% the system sound is atumatically 45%.
100/70 should be equivalent to 59/41...
PS Vita, Nokia N8
KuKiii9
PC Specification: Acer 7750g
Re: Action! 1.10.0
Tue Sep 18, 2012 6:05 am
In 1.20.0 add option Auto-Duck :)
This is very helpful.
keeper
PC Specification: q6600, gts 450, win 8
Re: Action! 1.10.0
Mon Oct 01, 2012 12:12 pm
Sometimes in Windows 8 logonui.exe crashes (with module action_x64.bin).
