Disarray
PC Specification: Windows 7.
Epic fail
Wed Sep 19, 2012 7:07 pm
So, I was using this program. It's great, I had the trial. Then, my program completely stopped letting me record anything, so I went and purchased it thinking it would fix the problem. It didn't. Awesome, then I had to make an account on here, jump through thousands of loops just to post on this website. Completely regret buying this program. I uploaded a picture of what my Action! looks like. I press f9 to start recording, nothing happens. I try it in all 3 settings. Doesn't work on full-game mode, "chosen" window mode, or simply desktop. Windows 7, 800gb hdd, 6gb ram. 4 core processors. AMD Radeon(TM) HD 6620G with 4gig memory left. 64-bit. I dunno what other kind of information you guys want, but I'm really pissed off that I bought some sh~t that doesn't even work. Don't get me wrong though, the program WAS great. Assistance please.
Re: Epic fail
Wed Sep 19, 2012 9:01 pm
Why didn't you just contact support desk?
StarGreen
PC Specification: Win7 x64/i7 920D/12GB RAM/GTX 670 FTW
Re: Epic fail
Thu Sep 20, 2012 10:32 am
This immediately sounds like an issue with your install of Windows than Action, so adjust your tone and stay calm whilst you contact the support team.
Disarray
Re: Epic fail
Thu Sep 20, 2012 4:30 pm
It used to work, like 2 days ago. so I highly doubt it's a windows problem.
RazrBit
PC Specification: I7-3770K, HD6950, 8 x64, 8GB
Re: Epic fail
Fri Sep 21, 2012 8:53 am
I had it once and I can guarantee it was something with windows. Luckily I was about to reinstall it and I never had the problem again, most likely because I'm trying to keep it bloatware free as much as I can but at the same time I test a lot of applications.
I know I had few instances where Action! shows "Recording" but it isn't and I can't do anything, but restarting windows usually fixed it.
StarGreen
Re: Epic fail
Fri Sep 21, 2012 10:27 am
Disarray wrote:It used to work, like 2 days ago. so I highly doubt it's a windows problem.
If your attitude is that of "I can have done nothing wrong" then it's almost 100% your fault, that's computers are, garbage in garbage out.
Re: Epic fail
Fri Sep 21, 2012 3:10 pm
But back to the problem. Did you install anything during these two days before Action! stopped working? This may be even a small update like graphic drivers.
ObserverJLin
Re: Epic fail
Mon Sep 24, 2012 11:17 am
If you have the time & energy, I have an old school fix.
Factory restore your system. Once OS re-install is complete, update everything. I.e. Windows update, DirectX, anti-virus etc. After everything is done install Action! and it'll work.
That worked for me when I had a similar problem.
