Silent Rain
PC Specification: Windows 7 Home Premium x64 (SP1)
Strong desync audio to the video on this music video - FIXED
Thu May 26, 2011 1:22 pm
On Other player (edited by admin), this video is played perfectly and without desync!
MediaInfo:
Code: Select all
General
Unique ID                        : 209881582929174124550293693854101415771 (0x9DE5B8F7FAC9542C9CB8CD6362C6275B)
Complete name                    : C:\Bleeding_Through-Death_Anxiety-WEB-720p-x264-2008-CFT.mkv
Format                           : Matroska
File size                        : 151 MiB
Duration                         : 3mn 30s
Overall bit rate                 : 6 033 Kbps
Movie name                       : Bleeding Through - Death Anxiety
Encoded date                     : UTC 2011-05-21 12:23:52
Writing application              : mkvmerge v4.5.0 ('Speed of Light') сборка от Feb  1 2011 02:10:32
Writing library                  : libebml v1.2.0 + libmatroska v1.1.0
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 5 frames
Muxing mode                      : Header stripping
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 3mn 30s
Nominal bit rate                 : 5 800 Kbps
Width                            : 1 280 pixels
Height                           : 720 pixels
Display aspect ratio             : 16:9
Frame rate                       : 30.000 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.210
Title                            : Bleeding_Through-Death_Anxiety-WEB-720p-x264-2008-CFT
Writing library                  : x264 core 115 r1995 c1e60b9
Encoding settings                : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=7 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5800 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Audio
Format                           : MPEG Audio
Format version                   : Version 1
Format profile                   : Layer 3
Mode                             : Joint stereo
Codec ID                         : A_MPEG/L3
Codec ID/Hint                    : MP3
Duration                         : 3mn 30s
Bit rate mode                    : Variable
Channel(s)                       : 2 channels
Sampling rate                    : 44.1 KHz
Compression mode                 : Lossy
Delay relative to video          : 24ms
Language                         : English
Test video: Bleeding Through - Death Anxiety
Re: Strong desync audio to the video on this music video - F
Thu Jul 21, 2011 10:26 pm
This should be fixed with latest versions.
