M1600wner
PC Specification: Intel 2500k ATI HD 6950 Windows 7
Editing the Raw output files in Sony Vegas 10
Mon Sep 24, 2012 12:24 pm
So. I heard about the program of yours, and went ahead to download the Trial version.
Everything is fine, except the thing with editing it. As far as i know, you guys claim to have Fixed it, but it doesent seems so.
Whenever i try to Punch these little bastards into my Video editing Program, it comes up with the following error -
You know, this Program has ALOT of potential, but you are loosing customers with bugs like that.
Re: Editing the Raw output files in Sony Vegas 10
Mon Sep 24, 2012 1:41 pm
Check if your raw file have 5.1 audio. If yes, Sony Vegas won't import it. To avoid situation like this untick "Allow multi-channel audio recording" if you are recording videos that may have 5.1 audio.
M1600wner
Mon Sep 24, 2012 1:54 pm
Looks like i solved the Problem - Thats how i did it
1.) Go to your Installation folder for "Action!"
2.) There is a File called "ficvdec_x64.reg" or "ficvdec_x86" (I guess which one you need to choose depends on your Operating System you are using)
3.) Profit.
So i'll guess there is nothing left to stop me from buying it.
Thanks for help anyway!
