olyteddy
PC Specification: i7 2600, Intel HD2000, W7 Ultimate
Audio Options?
Sun Sep 30, 2012 3:59 am
Are there any output options (other than 2.0 or 5.1) for the AAC audio that is used in export? 128kbps 2 channel is just so puny compared to the excellent video bitrate choices.
RuskiRozpierdalacz
PC Specification: q9550 gtx460 6gb W7HP 64bit
Re: Audio Options?
Sun Sep 30, 2012 6:06 am
Yeah, I said them, they answered to use VirtualDub.
Instruction:
radi wrote:Select from the top menu Audio, then Source audio, then choose Stream 2 (this is your microphone path) (obviously use that, you need). And then go to file select Save WAV and choose the file destination, press save.
Premiere Pro, Action! user. I still believe that I can help someone on this forum.
Re: Audio Options?
Sun Sep 30, 2012 3:16 pm
RuskiRozpierdalacz wrote:Yeah, I said them, they answered to use VirtualDub.
Instruction:
I think it's not what he meant.
Currently there's no any other options for Audio output options, but we are planning to add some features in future versions.
olyteddy
Re: Audio Options?
Sun Sep 30, 2012 3:43 pm
Are there any better audio options if I were to use Splash Pro EX to encode?
Re: Audio Options?
Sat Oct 06, 2012 12:14 pm
olyteddy wrote:Are there any better audio options if I were to use Splash Pro EX to encode?
Currently no.
