karlu
PC Specification: AMD
Is it possible to record in real 720p ?
Mon Oct 01, 2012 2:46 am
So yeah I love your program but when you record in 720p it records in 1280x800 and not 1280x720 so on YouTube it looks terrible with those 2 black lines on the side of the video. I was wondering if there's a way to change the 1280x800 for 1280x720 .
Thanks alot ;)
Re: Is it possible to record in real 720p ?
Mon Oct 01, 2012 10:03 am
Is your computer screen aspect 16:10?
karlu
Mon Oct 01, 2012 11:51 am
Yeah, my maximal resolution is at 1680x1050.
Mon Oct 01, 2012 2:11 pm
karlu wrote:Yeah, my maximal resolution is at 1680x1050.
Sadly this is the problem. YouTube supports only 16:9. 16:10 gets black bars on both sides.
Maybe this will help you out - http://www.labnol.org/internet/embed-yo ... rmat/5806/.
vivan
Mon Oct 01, 2012 3:00 pm
If you want to record something in 720p - than you should select such resolution for display (or at least resolution with such aspect ratio), and then record.
However there are two more choices:
1) strech recorded video to 16:9
2) crop extra pixels from top/bottom of the video
I believe that any video editor could to this, however I don't think this is a reasonable solution, since video will be deformed.
PS Vita, Nokia N8
sinnfullduck
PC Specification: i7 2600k, radeon 6870, win7
Tue Oct 02, 2012 11:10 pm
The program works great in 720p for YouTube. Here is a link to show it. http://www.youtube.com/watch?v=SrPrZUo27oU
This was recorded with Action! in 720p mode while playing in 1080p. As long as the aspect ratios match between what you're monitor supports and what you're trying to record, you're fine. Otherwise, you get black bars unless you crop and resize.
