Kooch
PC Specification: i7 950, GTX 460, Windows 7 x64
Torchlight 2 Crashes on Start up
Wed Oct 10, 2012 11:04 pm
As the topic says, Action! causes Torchlight 2 to crash on start up. (I launch Torchlight 2 through steam, so I'm not sure if this problem only relates to the steam version of TL2.)
WORKAROUND: In order to use Action! with Torchlight 2 at the moment, you just need to start Action! AFTER you have launched Torchlight 2.
Re: Torchlight 2 Crashes on Start up
Thu Oct 11, 2012 1:09 pm
Thanks for reporting this problem and the workaround method. We will look into it and see if we can fix this.
Kooch
Fri Oct 12, 2012 8:49 am
No problem. Thanks for making a great program!
