maximebibi
PC Specification: windows 7 x64 geforce nvidia 560ti
sounds problem
Fri Oct 12, 2012 4:19 pm
I have a small problem
the sound of my video is not very clear, there is a slight eco ...
qualiter the video is great but the sound is way ...
cordially.
RuskiRozpierdalacz
PC Specification: q9550 gtx460 6gb W7HP 64bit
Re: sounds problem
Fri Oct 12, 2012 5:45 pm
There are lot of things could make that. Microphone can produce echo from speakers. You can make echo effect in audio codec. Acton! settings also can be not good. Do you use a microphone? Can you make some screenshots of Acton!, write name of audio card (or motherboard) and audio codec.
Premiere Pro, Action! user. I still believe that I can help someone on this forum.
