MrWonka
PC Specification: i5 3750k, Nvidia GTX560, 8GB Ram.
[request] Pause recording when alt-tabbing
Fri Oct 19, 2012 12:30 pm
I've been experimenting with Action! as a replacement for fraps. Using the workaround for Quicksync (enabling the output on a missing display) I've been staggered by the videos I can now get with such a low performance hit. Your product is really very very good.
That said I have an issue where alt-tabbing (or pressing the windows key) whilst recording a game will result in the video being stopped. I then usually forget to start the recording again when I come back and so nothing end up getting recorded. I'd like it so that when I do alt-tab away from the game the video pauses rather then stop and continues when I return to the game. Is this possible?
Thanks
Mr Wonka.
Re: [request] Pause recording when alt-tabbing
Fri Oct 19, 2012 12:56 pm
Actually it's not possible due the resolution change that happens when you switch from game to desktop.
MrWonka
Fri Oct 19, 2012 12:58 pm
Is it not possible to then start recording automatically when you switch back? Multiple videos would work I guess.
Sat Oct 20, 2012 2:40 pm
MrWonka wrote:Is it not possible to then start recording automatically when you switch back? Multiple videos would work I guess.
I'll ask our developers and let you know.
Blutaar666
PC Specification: Phenom X4 955, Nvidia 570GTX, Win 7
Mon Oct 22, 2012 9:17 pm
dont want to hijack this thread, but both problems could be solved with a small ahk script ;)
