zougar
PC Specification: i7, RAM 12Gb, 2xNVIDIA 460 GT, Win 7 x64
2 displays
Fri Oct 19, 2012 8:34 pm
Downloaded the latest mirillis Action 1.11 - installed = OK
I use 2 display.
Game: eve online
In Action I can capture one Display at time only. If I create an area which spawn from one display to the next one I can't capture.
Any solution ?
Re: 2 displays
Tue Oct 23, 2012 6:19 pm
Hi, currently Action! can record only area of 1 desktop. If you wish to record second display you need to switch active desktop to 2nd display by pressing f8 hotkey. But it is not possible to record picture from 2 desktops at the same time to 1 output video.
When using Desktop region mode, frame becomes grey when selects area of 2 displays and recording cannot be started.
RuskiRozpierdalacz
PC Specification: q9550 gtx460 6gb W7HP 64bit
Re: 2 displays
Tue Oct 23, 2012 6:21 pm
Huge thanks, I also had problem with this.
Premiere Pro, Action! user. I still believe that I can help someone on this forum.
Re: 2 displays
Tue Oct 23, 2012 6:24 pm
At the moment im not sure how nvidia does it but with amd graphics card you can set eyefinity on and then record many displays at the time.
