chrySS123h
PC Specification: nvidia gt8600
Action! 1.11.0 problem [EDIT]
Mon Oct 22, 2012 8:14 am
Hi, i use Action! 1.11.0 games recorder but .. when i try to record my gameplay at format .avi 720p everything works fine but.. when i try to upload it on youtube it uploads but youtube processes the video and it says that " Processing of the video failed. Please make sure you are uploading a supported file type. " and youtube supports .avi formats.. i tried to record at .mp4 it uploads with no problem but the quality is 420p :( what can i do?
EDIT: I partially solved the problem I was finding that I need to export file directly to youtube through export.. but it gives me this error Connection with remote server failed!
RuskiRozpierdalacz
PC Specification: q9550 gtx460 6gb W7HP 64bit
Re: Action! 1.11.0 problem [EDIT]
Mon Oct 22, 2012 3:04 pm
Export it to 1080p (high) or to 720p(high), and send it to YT. For 1080p use 6-10 mb/s and for 720p use 3.5-5.5 mb/s. Actually i saw, that program doesn't alow to export 480p (854x480). Mirillis, for YT should be 854x480 or 640x360 if not HD. Source: http://support.google.com/youtube/bin/s ... e=guide.cs
Premiere Pro, Action! user. I still believe that I can help someone on this forum.
chrySS123h
Mon Oct 22, 2012 4:15 pm
RuskiRozpierdalacz wrote:Export it to 1080p (high) or to 720p(high), and send it to YT. For 1080p use 6-10 mb/s and for 720p use 3.5-5.5 mb/s. Actually i saw, that program doesn't alow to export 480p (854x480). Mirillis, for YT should be 854x480 or 640x360 if not HD. Source: http://support.google.com/youtube/bin/s ... e=guide.cs
No still can't upload i tried to do like you said but the same error appears...
chrySS123h
Mon Oct 22, 2012 4:38 pm
[EDIT] Sorry for bothering you guys so sorry.. i resolved the problem with export on youtube... but.. when i look in my account there is no video and when i look at my uploads I see the video that was supposed to be uploaded and under the videos it says that " Failed (unable to convert video file) "
RuskiRozpierdalacz
Mon Oct 22, 2012 5:49 pm
At least it. Are you sure you upload mp4 AVC video, not original avi?
chrySS123h
Mon Oct 22, 2012 5:58 pm
RuskiRozpierdalacz wrote:At least it. Are you sure you upload mp4 AVC video, not original avi?
If i choose .mp4 format i have only 420p ... and i want it in HD..
vivan
Mon Oct 22, 2012 7:35 pm
If you want HD, then
1) Record video in "AVI" format. Action! will use FICV codec for recording (it's proprietary codec, so youtube doesn't support it, however it's very fast and allows you to record video in HD without stressing CPU much).
2) And then export it (to mp4 with AVC/H.264, that everything supports). If you have troubles with uploading it to youtube via Action! - try web interface (http://www.youtube.com/my_videos_upload)
PS Vita, Nokia N8
chrySS123h
Tue Oct 23, 2012 1:26 pm
vivan wrote:If you want HD, then
" AVC " is .. any video converter? if yes, then.. i don't have that option to convert it to h.264 ...
RuskiRozpierdalacz
Tue Oct 23, 2012 1:56 pm
No, AVC is Advanced Video Codec, known as h.264.
chrySS123h
Tue Oct 23, 2012 5:50 pm
RuskiRozpierdalacz wrote:No, AVC is Advanced Video Codec, known as h.264.
so if I download this codec.. how can I converte .avi files recorder with Action! in mp4 h.264?
