Splash PRO 1.8.0
Mon May 30, 2011 11:18 pm
What's new in Splash PRO 1.8.0?
* Automatic interlace detection added for Motion² mode
* Audio/video synchronization improvements for some MKV files
* Multi-channel AAC audio playback improvements
* FLAC audio playback improvements
* H.264/AVC software video decoding improvements
* Aero style look for Splash main window added (Windows Vista and Windows 7)
* Stability improvements
Re: Splash PRO 1.8.0
Mon May 30, 2011 11:25 pm
Ghost wrote: * Automatic interlace detection added for Motion² mode
This option is enabled by default from version 1.8.0 and it disables automatically Motion² for interlaced videos.
Please note that for some progressive files that are incorrectly encoded/described as interlaced you must disable "Automatic interlace detection" option to make Motion² work.
EvertonMonkey
PC Specification: Core i3-330M, Intel HD Graphics, Win7x64
Thu Jun 02, 2011 11:11 am
EvertonMonkey wrote:Since updating to 1.7.1 I seem to be having a similar problem to what I had in 1.3.2 using a core i3-330M Intel HD Graphics, the video is not jerky and not smooth, although enabling video overlay seems to fix the issues. Below is the quote of my previous post problems from the other thread :
EmZvr wrote:I have a problem with thelatest version 1.3.2. I'm using the Intel HD video card integrated in Core i5 and when VIdeo overlay is disabled all the movies I play have a huge lag. When enabling video overlay everything is okay but every time I run Splash Pro it changes my theme to WIndows 7 Basic.
I installed the old version and without video overlay I can play every movie without problems.
I'm having the exact same problem on my Core i3-330M, Intel HD Graphics system. Worked perfectly before the update and is jerky a hard to watch with the update. Video overlay makes it better, but also makes the windows basic graphics profile activate. Please help.
And the URL : http://www.mirillis.com/forum/viewtopic ... 2610#p2610
Any idea if my previously posted problem has now been fixed ? Will test it one I get home from work, but just wondered if it had been noted as there was no response on my previous post.
lbamda
Thu Jun 02, 2011 1:24 pm
Awesome update! Many problems, from my list are solved:
1) After version 1.5.0 exit till now doesn't work hardware deinterlacing on 60i source on radeon video card; Solved
2) Not support 'ASS' and 'SUB' (from DVD) Subtitles;
3) On subtitles 'PGS' it is not displayed more than two lines;
4) On the menu opening by the right button of the mouse, doesn't work keyboard (arrows) - it is impossible to use remote controls;
5) Not support chapter in mkv;
6) Not support name track in mkv (support only track language).
7) Not support 4.0 (quadro) audio setup.
8) If audiotrack in mkv video file only one and it LPCM, it isn't play (silence) - is highlighted by red color. If it audiotrack compulsorily to choose, player under abnormal finishes work with an error. Solved
And one more serious problem:
9) Incorrectly decodes 6.1 FLAC and LPCM audiotracks (in mkv video files) for stereo audio-configuration (without center and sub chanell).
lbamda
Tue Jun 07, 2011 9:32 am
lbamda wrote: 1) After version 1.5.0 exit till now doesn't work hardware deinterlacing on 60i source on radeon video card; Solved
It I have hastened with conclusions - on 1080i / 60i video deinterlacing doesn't work - I can send an sample.
EvertonMonkey
Sat Jun 11, 2011 6:53 pm
Any update on my previous post? Thought there would be some kind of response even just to say it's been looked at :-(
tuvi123
Sat Jun 11, 2011 7:11 pm
What about BOLD subtitles support? and the ability to choose subtitle font size by numbers?
also still no IDX/SUB support.
Anonymoose
PC Specification: GTX260 / Q6600 / W7 SP1
Sun Jun 12, 2011 3:54 am
another great release!
much less visible artifacts, but it still have those artifacts affecting cables or less passing against a fast almost solid background
Nielo TM
Sun Jun 12, 2011 12:39 pm
They all do. Even TVs. There's still no consumer grade real-time FRC that is capable of correctly converting low-motion contents to high-motion. So when the processing becomes too complex, FRC is disabled or only certain sections of the motion is processed.
But on the PC it's a different story. Developers can tap into the power of the GPU to massively increase detection and improve the quality of the synthetic frames. Can't wait for mirillis to bring out CUDA support for Motion2.
Anonymoose
Mon Jun 13, 2011 12:13 am
I know :)
that's why I'm saying it's much better than the last release that had a bunch of shudder borders around people and weird stuff, it's all gone now
I've been using this since 1.4.1
