arnulf
2 monitors crashes Splash
Tue Jan 19, 2010 2:44 am
When I try to move Splash from 1. monitor to 2. monitor program crashes.
It only crashes if HW acc. is enabled, it also crash when opening video file on 2. monitor.
With no HW acc. no picture on 2. monitor, and I can move between 1 & 2 without program crash.
-- Added
Version 1.3 fixed this problem, but there are some glitches with sound & video, it may be a
buffer problem. With LiveTV, every other seconds sound halts for a ms, very annoying.
(it seems to disappear if StopTV & WatchTV is pressed one or several times)
When switching from Windowed to Fullscreen (or back) on monitor 2 (or 1), a black field (up left)
flashes on monitor 1.
Love to see present EPG program, assume Next is added in v1.4? (and full EPG in TV version)
Hopefully LiveTV Subtitles also is added in v1.4?
Looking forward for version 1.4 :)
I use Asus EAH3450/DI with 1: DVI 1680x1050 monitor/ 2: VGA 1920x1080 monitor. OS: WinXP.
Love to see a program that supports GPU acc. & HE-AAC LATM as used in Norway !
Love Splash !
Re: 2 monitors crashes Splash
Thu Jan 21, 2010 1:04 am
Hi arnulf,
We confirm this problem and stability should be improved in next Splash Lite version.
On WindowsXP Splash can render video only on 1 display in extended desktop mode.
Thank you for reporting the problem!
