pochlaniacz
PC Specification: Core2Quad Q6600, GF GTX 460, Win7 x64
Features request
Sun Jun 05, 2011 10:21 pm
First of all, I have say that I am very pleased by Splash PRO, especially by Picture2 functionality. After two weeks of use I bought full licence, because my HD videos played so smooth and looked so crisp that I just can't live without it :)
Of course nothing is perfect, so I put here few features which could improve this excellent player:
- Option to customize all keyboard and mouse shortcuts - via proper tab in settings
- Option to switch on/off using of multimedia keys
- Possibility to open several players in the same time - e.g. for comparing video shots
- Option to automatically fill default playlist with all video files from directory containing just opened file
- Keyboard shortcuts to change synchronization of subtitles (in 0.5 sec steps)
Maybe this topic is worth making sticky?
Re: Features request
Thu Jul 21, 2011 10:28 pm
Hi and thank for a feedback.
- custom hotkeys settings are planned for future versions
- can you please describe why do you need to switch on/off multimedia keys?
- We are considering this but it can bring up some problems (in example use of GPU at the same time by 2 players). At the moment you can make this possible by changing exe name in Splash installation folder. This should work fine.
- Auto fill suggestion will be placed on our list of features to consider for future versions, this is a new suggestion i think. Thanks!
- hotkeys for lipsync are planned to be added.
I will make the topic with suggestions/plans for future versions and make it sticky.
deadspeak
PC Specification: intel core i3 530, win 7 ultimate 64bit,
Sun Aug 14, 2011 8:26 am
Ghost wrote:Hi and thank for a feedback.
This is the only thing holding me back from buying the product right now, if i could do this it would solve my current remote control issues (as my remote simulate s keystrokes) all other players such as MPC-HC and vlc already do this, but their quality and eash of use is no where near splashpro.
As soon as you have this you'll have another customer :D
pochlaniacz
Wed Aug 17, 2011 12:52 pm
Ghost wrote: - can you please describe why do you need to switch on/off multimedia keys?
There is a bug, I belive - Splash intercepts multimedia keys events, but doesn't react on them. For example, my volume control keyboard keys are mapped to Windows "master" volume - but when I launch Splash I cannot set Windows volume by these keys anymore, Splash itself doesn't react on these keys and they behaves like disabled.
Best solution for me would be option to switch off/on reacting to multimedia keys OR adding multimedia keys to shortcuts settings.
Thu Sep 15, 2011 9:04 pm
Thank you very much for explanation. What is your keyboard model?
pochlaniacz
Fri Sep 23, 2011 8:52 pm
This is Dell SK-8135, with volume knob, working on Windows 7 Home x64. Twists of knob are sent by USB as key presses.
Thu Mar 22, 2012 12:17 am
pochlaniacz wrote: This is Dell SK-8135, with volume knob, working on Windows 7 Home x64. Twists of knob are sent by USB as key presses.
Thanks I will add this to our list to check this.
