mel2401
PC Specification: Intel I7 3.6ghz, MSI 690 GTX, Win 8 64
Auto Resume Problems
Wed Jun 08, 2011 3:12 pm
Is anybody else having problems with the auto resume playback feature? It appears to be completely random whether it decides to resume or play from the beginning of a file.
aviwil
Re: Auto Resume Problems
Tue Jun 21, 2011 11:40 am
Yes , I have the same problem .
Bazikcho
PC Specification: AMDx2 2.5Ghz - 4gb - 780G - 1TB - win764
Tue Jun 21, 2011 6:05 pm
"When I wrote this only God and I understood what I was doing...
Now only god knows !"
aviwil
Tue Jun 21, 2011 6:30 pm
Thanks Bazichko - I understand that it must be manually added to the playlist , in order for this to work .
Tue Jul 19, 2011 4:44 pm
mel2401 wrote:Is anybody else having problems with the auto resume playback feature? It appears to be completely random whether it decides to resume or play from the beginning of a file.
Please try latest 1.10 version.
It should auto resume files also not beeing stored on playlists.
There is also a condition that last played position had to be over 3minutes and then file will be resumed.
It is possible to change this in Splash config file, if you are interested please let me know and I will
guide you how to do it.
