klocklimek
PC Specification: Phenom II 965, GTX 570, Windows 7
Strange sound problem when recording microphone.
Fri Nov 02, 2012 9:00 pm
Hi! I have strange problem with audio in recorded file when i check " Record microphone into separate audio track (AVI)".
Regardless of the selected audio capture options, I got terrible sounds in audio track. You can hear them here:http://www.youtube.com/watch?v=1sDQP0hGMeA at 1:43.
Recording options:
AVI
1080p
30FPS
Record system sounds
Record on button down
What can cause this problem?
Re: Strange sound problem when recording microphone.
Sat Nov 03, 2012 11:56 am
Thanks for reporting this problem. Next Action! version will include audio improvements which should solve your problem. New version should be available soon. Meanwhile could you tell us what microphone are you using?
klocklimek
Sat Nov 03, 2012 12:12 pm
Thanks for quick reply. I am using Logitech ClearChat Pro USB Headset.
Mon Nov 05, 2012 12:41 pm
It may be caused by the USB output used by your microphone. Do you have any other microphone that you can plug in to see if there's a difference? This could confirm the problem.
klocklimek
Thu Nov 22, 2012 5:01 pm
A few days ago I bought a headset "SteelSeries Siberia v2" and the problem persists, regardless of whether I connect the headphones to the attached USB sound card or to the integrated(
Realtek ALC889).
