FRAGorDIE
No video, only audio.
Mon Jan 18, 2010 1:00 am
Hi there.
Here is my PC config:
COMPUTER: DESKTOP
GPU VENDOR: nVidia
GPU MODEL: AMD Sempron 2800+
1.61 GHz, 1,00 GB RAM DDR2 (no idea for the amount of VRAM)
ATI Radeon x700 PCI Express 128 MB
OS: Windows XP Proffesional SP3 x32
.....well here is my problem. When I start Splash it looks just great and I really want to use it but here's the problem :!: When I start a movie with the Splash there's only audio but not video. I just dunno whats the problem cuz all other player works great but Splash is giving me only audio when I start a movie. Please help! :(
Here is what I see :(
only audio.jpg (86 KiB) Viewed 13297 times
Florin64x
Contact: Yahoo Messenger
Re: GPU Compatibility List (H.264/AVC)
Tue Jan 19, 2010 12:20 pm
FRAGorDIE wrote:Hi there.
COMPUTER: DESKTOP
GPU VENDOR: nVidia
you cant run splash because your processor dont have SSE2... so thats why you dont have image...
Watchman
Tue Jan 19, 2010 2:24 pm
COMPUTER: DESKTOP
GPU VENDOR: nVidia
Hi All,
This is probably a different problem. Not all of AMD Sempron CPUs don't have SSE2 extensions (only Thoroughbred B/Thorton and Barton are not equipped with SSE2 but for example Paris and Palermo have SSE2). It seems the problem FRAGorDIE is describing here is somehow related to video display. We will further investigate this issue.
Thanks for the feedback!
Re: No video, only audio.
Thu Jan 21, 2010 10:12 am
COMPUTER: DESKTOP
GPU VENDOR: nVidia
Hi, we would like to ask you for some more info to investigate the problem:
1) please open windows command line, run dxdiag and open "display" tab to check what is your exact graphics card model.
2) open Splash info panel during playback (press "i") and check what stream type and video are detected.
