Sphinter
PC Specification: Acer
Error d3d11.dll
Sat Nov 03, 2012 7:06 pm
Hello, i installed rightly action, but when i start it, an error message appear:
"This application has failed to start because d3d11.dll was not found. Re-installing the application may fix this problem."
I try a lot of time to reinstall but he say all the times the same message.
The strange thing is that 2 month ago, before the unistalling, mirillis was working perfectly.
Some one have a solution?
Re: Error d3d11.dll
Mon Nov 05, 2012 12:29 pm
Do you have latest DirectX installed on your PC?
