mistralbreton
PC Specification: c2duo e6600 4 GO 1000GO
SPDIF / BISTREAM miss HELP
Sat Jun 25, 2011 10:00 pm
Hi all i want to purchase this fantastic player but i try before. God was with me, because the video playback is OMG verry smooth and good 4 me. But in sound i can't chosse spdif option! Look
Uploaded with ImageShack.us
So i got the lastest driver of my manufacturer soundcard. Please help me. The sound works un 5.1 mode, but i feel poor real 5.1 mode...
HELP
my soundcard is : Auzen X-Studio 5.1
Description: Improve your audio quality and performance with the Low Profile Auzen X-Studio 5.1 PCI Sound Card powered by the VIA High Quality ICE 1723 audio processor with 24-bit/96kHz High Quality Digital Audio.
Features: Powered by the VIA High Quality ICE 1723 audio processor, the Auzen X-Studio 5.1 PCI Sound Card provides 24-bit/96kHz High Quality Digital Audio, includes Auzentech´s signature swappable OPAMP for the front-left and front-right channels, internal digital output two-pin connector, a Microphone Pre-Amplifier, and support for the QSound Labs 3D Surround Engine.
Convenience: The Auzen X-Studio 5.1 PCI Sound Card supports HD front panel audio connections and includes both Standard-Profile and Low-Profile brackets.
Best-in-Class Warranty: Register within 30-days to receive an extra year of coverage, for a total Two-Year Warranty protection.
thanks for time spend on my issues.
mistralbreton
Re: SPDIF / BISTREAM miss HELP
Thu Jun 30, 2011 8:46 pm
hi all. No ideas ? i just fo on seven 64bit, and no more progress. Still unclikable .. :'(
mistralbreton
Fri Jul 01, 2011 11:30 am
or there is a way to send audio via another software ? matroska or ac3filter ?
mistralbreton
Sun Jul 03, 2011 7:57 pm
IS there any staff here in this board? Mirillis have some guys working on troubles ? :?:
mistralbreton
Fri Jul 08, 2011 8:20 pm
HELP UP
MIRILIS HELP ME OR I WON T BUY YOUR PRODUCT !! HELP ME HELP YOUR CUSTOMER
hln
PC Specification: MacBook Pro, thunderbolt, ZBox AD03 HTPC
Mon Jul 11, 2011 12:30 pm
Did you download the 30 day trial "Pro" version and not able to bitstream? It's hard to tell from your screenshot.
The "free version" does NOT have the ability to bitstream. Only the Pro version has SPDIF/Bitstream and it works great for me.
mistralbreton
Wed Jul 13, 2011 9:36 pm
and you have the same soundcard than me ?
Tue Jul 19, 2011 4:48 pm
Thank you for reporting a problem.
We were reported by several users using Auzentech X-fi cards that it works fine with Splash.
On this forum there is a user Denonic using Auzentech with Splash.
Your card model should also work fine with Splash.
We will do our best to investigate the problem and find a solution.
Did you install drivers provided by the Auzentech on CD/DVD or you let Windows to install drivers automatically?
Did you update drivers to the latest available online?
mistralbreton
Thu Jul 21, 2011 7:47 pm
Hi and Thank you to spend time on my issues.
I try with the CD driver and didn't work. I try with the latest driver on the website, didn't work. I use windows 7. Driver version is 5.12.1.3655 and i reach to the 1.10 splash pro ex and always not detected.
tanks to spend your time, but man, you must know that i'm not familiar with buying somes applications, if you see what i mean, but OMG this time i really want buy your product because i love this and i get the same quality picture than my TV samsung 200hz. So fix my issues and you will receive my purchase 2 secs later ;)
Thanks you verry much, and some appologies for my bad english, I'm french.. :D
mistralbreton
Thu Jul 21, 2011 7:51 pm
And i just asked to the user denonic in PM mode to check if he have the same soundcard and check the drivers.
thanks a lot.
