Splash PRO 1.9.0
Fri Jul 01, 2011 4:25 pm
Splash PRO 1.9.0 is now available!
What's new in Splash PRO 1.9.0?
* Major Motion² video quality improvements
* Improved MPEG-2 software decoding performance
* Improved H.264/AVC software decoding performance
* Stability improvements
Update includes major Motion² video quality improvements, artifacts number should be significantly reduced.
This version also solves a problem with application initialization ("This application cannot be executed. ERRORS:
0x8009000f, 0x8009000b, 0x8009000f, 0x8009000b" and other error numbers).
Nielo TM
Re: Splash PRO 1.9.0
Sat Jul 02, 2011 2:00 pm
WOW!
There's far less artifacts when MCFI is enabled (almost as good as top-end LSI based MCFI).
gmit
Sun Jul 03, 2011 12:20 am
If I were you, I would name this version 19.0.0! :D The result is impressive...
val
PC Specification: XP SP3, Dual Core Atlon at 2GHz, 2GB RAM
Sun Jul 03, 2011 6:30 am
This player is the only one handling the full HD video from my new Sony HX9V. Good work! My machine is kind of dated (XP Pro SP3, Dual Core Athlon @ 2GHz) but it plays the videos great. I got the Pro EX 30-day trial but for some reason the Playback Options controls cannot be enabled. Only the Audio Boost works. Any ideas?
Thanks!
tuvi123
Sun Jul 03, 2011 10:34 am
big update yes thank you for that, but you always update and improve the same features..
why there is still not support for pre defined size / more fonts and BOLD subtitles?
vivan
Sun Jul 03, 2011 4:07 pm
Yeah, quality of frame interpolation is now much better + less artifacts...
Also it uses just 600 MB of RAM (e.g. SVP uses up to 2,5Gb because of lot of threads) and CPU load is about 20% (but it doesn't use HT threads at all, so real load without HT is about 40%).
But CPU load is unballanced, but since I haven't seen any lags because of this it's ok...
PS Vita, Nokia N8
metal005
PC Specification: AMD1090T, HD4870, WinXP 32bit
Sun Jul 03, 2011 7:49 pm
very nice update!! good job :D
tuvi123
Tue Jul 05, 2011 4:32 pm
Also shourcut for increasing/decreasing subtitle font size is a must have feature 8-)
I really hope and wwish that on the next update you imrove subtitles support (BOLD/pre define sizes/more fonts etc..)
lbamda
Tue Jul 05, 2011 10:50 pm
My bugs and problems list for Splash PRO (and EX) 1.9.0:
1) After version 1.5.0 exit till now doesn't work hardware deinterlacing on 60i source on radeon video card; (Partially solved, but on some video files doesn't work hardware deinterlacing) - I have sent sample
2) Not support 'ASS' and 'SUB' (from DVD) Subtitles;
3) On subtitles 'PGS' it is not displayed more than two lines;
4) On the menu opening by the right button of the mouse, doesn't work keyboard (arrows) - it is impossible to use remote controls;
5) Not support chapter in mkv;
6) Not support name track in mkv (support only track language);
7) Not support 4.0 (quadro) audio setup;
8) Incorrectly decodes 6.1 FLAC and LPCM audiotracks (in mkv video files) for stereo audio-configuration (without center and sub chanell);
9) Not played wav audio files;
10) (New bug!) Playing of some files mkv (blu-ray remux) stops with an error and incorrect closing of the program; - I have sent sample
11) (New bug!) If at playing mkv a file to be switched from AC3/DTS audiopaths on LPCM audiopaths, such switching occurs long and as a result there is a wrong synchronization of a sound and the image - it is necessary to stop and again to start play.
Thu Aug 11, 2011 12:16 am
val wrote:This player is the only one handling the full HD video from my new Sony HX9V. Good work! My machine is kind of dated (XP Pro SP3, Dual Core Athlon @ 2GHz) but it plays the videos great. I got the Pro EX 30-day trial but for some reason the Playback Options controls cannot be enabled. Only the Audio Boost works. Any ideas?
Thanks!
Please make sure that you have best quality enabled in playback options.
Stop all playback and enable this option.
tuvi123 wrote:big update yes thank you for that, but you always update and improve the same features..
Yes, we are sorry but it is still not added.
tuvi123 wrote:Also shourcut for increasing/decreasing subtitle font size is a must have feature 8-)
Thanks for suggestion about shortcuts for font size.
Subtitles improvement are going to be available in upcoming 1.11 update.
lbamda wrote:My bugs and problems list for Splash PRO (and EX) 1.9.0:
About PGS problem, do you expereince it with all PGSsubtitles in different video files?
