lbamda
Very long opens heavy files in mkv (blu-ray remux)
Wed Jul 06, 2011 8:40 pm
At opening of the big and heavy files in mkv (blu-ray remux) the player very long opens them (till 2-4 minutes) - that it does at this time and whether it is impossible to reduce this time?
pirotrav
PC Specification: i7 2600k, radeon hd6870, 8gb RAM, win7
Re: Very long opens heavy files in mkv (blu-ray remux)
Thu Jul 07, 2011 5:03 am
Almost all of my collection is composed of blu-ray rips, some reaching into 50 gb. None take more than a few seconds to open. What sort of hardware do you have? Low speed processor or defective hard drive perhaps? Also, how much ram do you have?
lbamda
Wed Jul 13, 2011 7:44 am
At me 4-core Intel 2500K. Ati Radeon 5750. How much it is a lot of at you 50GB blu-ray remux's? Not on any big files it is shown. Somewhere at once it is started, and somewhere it is necessary to wait till 5 minutes! I know precisely that it is connected with video. All MPEG2 ' mkv ' files are started at once. Some H.264/VC1 ' mkv ' files are started at once, some in a few minutes! At you what video card?
pirotrav
Mon Jul 18, 2011 6:25 am
Your hardware is far more than sufficient. The 5750 isn't a super high end gaming card, but more than adequate for playing back hd footage. Splash is quite light. I would recommend enabling and disabling video acceleration. Probably won't resolve the issue, but its worth a shot. Also update to the latest catalyst control center. Finally, try re ripping the file and putting it on a different drive. VC-1 is a poorly written codec in my opinion, however, that a lot of programs have difficulty handling.
Thu Jul 21, 2011 10:38 pm
Do you experience this problem with all mkv files from different sources
or this is a problem with mkv files from one source?
It looks like there is something wrong with files and it causes a problem to Splash.
We have tested a bunch of big mkvs in our lab and all open very fast.
