rediscover
PC Specification: AMD 965(3.4GHZ),GEFORCE460,WINDOWS7
Player freezes when using Motion2
Tue Jul 12, 2011 12:09 am
Whenever I turn on the Motion 2 setting, no matter the amount, it freezes my video. The weird thing is that I'm only having trouble with a certain anime, which is in 1080p. Other animes which I watch in 760p or lower do not freeze when using motion 2. I really want to figure this problem out because Motion 2 is such a great feature and it would be amazing for me to get it to actually work. It makes animes look far nicer in comparison.
My specs might be of some help, so here they are :
AMD965 QuadCore BE (3.4GHZ), NVidia Geforce 460 Superclocked, Windows 7, 6g of ram
On a side note, my friend has the same issue as well. He also freezes at some parts of the anime. Another thing is that if I go to another part in the anime after it freezes, it will unfreeze until it finds a part to freeze at once again. Any help is appreciated :D
Re: Player freezes when using Motion2
Thu Jul 21, 2011 10:36 pm
Does it freeze with hardware acceleration enabled and disabled?
Is it possible to trim a short sample and send us for testing?
