szcljin
Incorrect DVB-T frequency range for Taiwan
Thu Feb 11, 2010 2:31 pm
I downloaded Splash Lite 1.2 and installed it on my Revo R3600 today. When scanning the DVB-T
channels, I noticed that the starting and ending frequencies will never work in Taiwan, where I
live in. The current DVB-T channels in Taiwan occupy the frequencies between 533MHz and 599MHZ,
6MHz apart. But the setting inside Splash Lite's dropdown box is from 470MHz to 872MHz, 6 Mhz
apart, which will never match the correct channel frequencies of Taiwan's DVB-T.
Is there a workaround so I can manually input the starting and ending frequencies for channel
scan?
Thanks in advance.
szcljin
Re: Incorrect DVB-T frequency range for Taiwan
Fri Feb 12, 2010 12:19 pm
As I already know the frequencies of DVB-T channels in Taiwan, Can I manually edit the channel setting file? If
so, where can I find the relevant information, like the filename of channel setting, and its data format?
Thanks in advance.
Fri Feb 12, 2010 5:21 pm
Hi szcljin and welcome to forum :)
Thank you very much for reporting the problem!
Frequency list will be updated with coming Splash Lite 1.3.
Frequency lists are not available for editing by users.
