Splash PRO 1.10.0
Fri Jul 15, 2011 10:39 pm
What's new in Splash PRO 1.10.0?
* Improved video sharpness in GPU accelerated Motion² mode
* Support for HDTV video outputs (24p/30p/50p)
* Support for 72/75Hz monitor refresh rates
* Up to 200 previously opened files remembered for auto-resume function
* Fixed 100% and 200% windowed video size
glm
PC Specification: q6600, gtx260OC, win7 x64
Re: Splash PRO 1.10.0
Sat Jul 16, 2011 8:04 am
Still disappointing... There is no spdif out (through my creative x-fi xtreme music sound card) or choppy sound and image freeze (when spdif is on). I want play movie sound on my Yamaha 7.1 reciver.
Good image result, but still 70% load from my quad when motion2 is activated.
I'll skip this version to buy till sound will work fine. I wonder wich version you'll be able to fix spdif problem?
sjc1963
PC Specification: Windows 7 Home Premium 32bit
Sat Jul 16, 2011 2:14 pm
So, the last version wasn't really 1.90.x but 1.09.x instead?
vivan
Sat Jul 16, 2011 2:49 pm
PS Vita, Nokia N8
sjc1963
Sat Jul 16, 2011 11:07 pm
Its still confusing.....
n00b
PC Specification: i5-2500K HD3000 Windows7 Pro 64bit
Sun Jul 17, 2011 10:52 am
Splash Pro works fine on my 19" LCD monitor (1280 x 1024) via DVI but when I switched to 42" LCD TV (1080P) via hdmi, the audio getting out of sync and the playback is stuttering, any idea why?
I am using i5-2500K with Intel IGP HD3000, 8GB DDR3 on Windows 7 Pro 64bit.
Thanks~
_____________________________________________________________________________
update: ok, i hv found the answer, apparently i didn't set my LCD TV to 60Hz; with 60Hz no more stuttering :lol:
glm
Sun Jul 17, 2011 12:08 pm
I post a replay, but I cannot see it. why?
vivan
Sun Jul 17, 2011 7:00 pm
Suggestion: 10 bit support (High 10 Profile).
Seems that in future it would replace 8 bit, since it provides better quality at same birate (or lower bitrate at same quality).
PS Vita, Nokia N8
Malwin
PC Specification: Intel Graphic GM45 , Win 7 x86 Pro
Tue Jul 19, 2011 2:13 pm
What about possibility of using external codecs especially audio codecs. I haven't seen better audio codec than ac3filter to decode DTS and Ac3. ATM there is no possibility to configure audio in splash pro so watching movies with 5.1 audio track on 2.0 audio system is not pleasant. There is no option to increase/decrease each channel or even mixing matrix.
People who develope ac3filter project made great work. Their filter contain many useful featers like : mixing matrix , Dynamic range compression ( great option especially when watching movies at night ) , channel configuration , advance channel mapping and mixing so no more quiet dialogs during playing 5.1 audio on 2.0 audio system and much more.
Ac3filter is a complex audio codec and allows to adjust the sound in almost any way. I hope you will consider to allow using external filters.
hln
PC Specification: MacBook Pro, thunderbolt, ZBox AD03 HTPC
Wed Jul 20, 2011 1:03 pm
I wouldn't bother suggesting anything as Mirillis WILL NOT listen to customers. Very disappointed with this awful company. No thanks, you can keep you 1.10.0 or many more will be released in the next few weeks.
