MrRDjS
PC Specification: mbp 2011 13" i7-2620m win7x64
Macbook Pro 2011 13" Intel Core i7-2620M Motion2 ultra??
Sat Jul 23, 2011 12:31 pm
I'm running Splash pro 1.10.0 version on my macbook pro 2011 13" with an Intel Core i7-2620M processor.
I'm Running windows 7 x64 via bootcamp and run splash pro with charger plugged in and power settings on maximum (no power savings etc).
Shouldn't my proc be beefy enough?
Anonymous.07
PC Specification: i3 370M, Windows 7 SP1 Ultimate, AMD4650
Re: Macbook Pro 2011 13" Intel Core i7-2620M Motion2 ultra??
Tue Jul 26, 2011 10:03 am
MrRDjS wrote:I'm running Splash pro 1.10.0 version on my macbook pro 2011 13" with an Intel Core i7-2620M processor.
I believe there's a bug in the product. There's another discussion going on about the same issue.
http://www.mirillis.com/forum/viewtopic.php?f=18&t=892
Thu Aug 11, 2011 12:26 am
Seems like your CPU model has only 2 cores.
You will be able to check Ultra 1080p with upcoming version as thi version will unlock Ultra 1080p for 2 and 3 core CPUs.
