fuvio
PC Specification: Windows 7 Home Premium x64
DTS-HD HR - bitstreaming - FIXED
Sat Jul 23, 2011 4:12 pm
I like bitstreaming functionality of this player, almost all formats work flawlessly - Dolby TrueHD, DTS-HD Master Audio, even the Dolby Digital+. But it doesn't work (at least for me) with DTS-HD High Resolution audio. This format is probably not widely used and I can live without it but here's an audio sample if someone wants to check it:
Bitstreaming works for me in MPC-HC and properly configured ffdshow with this sample.
Re: DTS-HD HR - bitstreaming
Mon Jul 25, 2011 9:37 pm
Thaks for reporting problem. Will check this sample.
What device do you use to bitstream audio (NVIDIA card, ATI card etc)?
fuvio
Tue Jul 26, 2011 7:23 am
Ghost wrote:Thaks for reporting problem. Will check this sample.
Currently Intel® HD Graphics 3000 (in i7-2600K CPU) but the result was the same when I tried AMD Radeon 6450.
Thu Aug 11, 2011 12:06 am
Should be fixed in version 1.11.
Thanks for reporting.
fuvio
Thu Aug 11, 2011 4:25 pm
Ghost wrote:Should be fixed in version 1.11.
Thanks. When can we expect this new version? :)
Thu Aug 11, 2011 4:46 pm
Now :)
http://mirillis.com/en/products/splashexport.html
fuvio
Thu Aug 11, 2011 8:02 pm
Well that was fast :) And the DTS-HD HR issue is fixed, thank you.
Sun Aug 21, 2011 8:17 pm
fuvio wrote:Well that was fast :) And the DTS-HD HR issue is fixed, thank you.
Thank you for confirmation!
