yterbium
PC Specification: Win7,Sony Vaio FW41E/H (T6400,HD4650)
Disable activating basic theme on splash start - SOLVED
Mon Jul 25, 2011 3:30 pm
first for all, thanks for this greate product .
But from latest version (.10) splash on startup allways active basic theme on windows 7 (and disable aero). How can I disable this behaviour=not activating basic theme on startup?
Thanks for advice.
Re: Disable activating basic theme on splash start
Mon Jul 25, 2011 9:39 pm
There are no chanes in 1.10 version that could result in disabling aero.
Please open setings/video and check the seting "Force video overlay",make sure that this option is disabled.
Do you have a Broadcom accelerator in your PC?
yterbium
Tue Jul 26, 2011 10:26 am
Yes ,
disabling "force video overlay" solve the problem. I had to enabled it and didnt thought , that this was the problem.
Many thanks,
and continue with this great player for HD. And I am very avaiting Splash BD, which will be able to play BD menus :-)
