NemesisII
PC Specification: C2D 2.4 Ghz NVIDIA Gf8400GS Win Xp Sp3
Problem with Picture2 !
Tue Jul 26, 2011 3:43 am
Hi ! I just uses Splash Pro yesterday !
The Picture2 is pretty good ! But I have a trouble when enable it.
The frame rate is ok, CPU usage is not so high but the image look weird ! see my screen shot bellow :
Disable Picture2 (Source Image) :
Enable Picture2 (form 1 to 10 also have same problem):
I mark it by yellow circle !
The movie above is Tron-Legacy ! (Time : 00:46:00).
Anyone know how to solve this problem , please help me ... !
Re: Problem with Picture2 !
Thu Sep 15, 2011 8:29 pm
Hi, this are most probably artifact from frames interpolation.
This is a side effect of Motion2, you can try to reduce this effect by setting lower Motion2 level.
There are still some scenes that can produce visible artifacts.
We hope to improve Motion2 in the future to make it not visible.
Return to “Picture²”
