rutark100
PC Specification: win 7 32bit
splash pro error while playforwarding
Wed Jul 27, 2011 7:44 am
im experiencing a very annoying problem while playforwarding a movie or song. When i run a movie/song forward it just stops responding and when it just closes.
here's a pic of what happens while playforward
Re: splash pro error while playforwarding
Thu Aug 11, 2011 12:07 am
Can you check if this happens only with AVI with mp3 audio?
And does the problem repeat for this scenarios:
1) Open avi file and start playback, do not forward playabck.
Open right mouse button menu, slect audio track menu and select "disabled". Check if this solves a problem on your PC.
2) Open avi file and start playback, do not forward playabck.
Open right mouse button menu, slect video track menu and select "disabled". When no video is available try to forward and check if this solves a problem on your PC.
mongol
PC Specification: Windows 7 64 Bit
Mon Aug 15, 2011 10:47 pm
I have the same problem with some videos, playforwarding just make application to crash. Other videos plays fine.
P.J
Wed Aug 17, 2011 4:35 pm
Would you upload the file you have problem?
Sun Aug 21, 2011 8:26 pm
Guys, please check what is audio codec in this files (press i to show info panel).
Please also check if problem occurs with audio track disabled (right mouse butto menu - audio track - disable).
wez
PC Specification: Win7 x64 Home Premium & Ultimate
Thu Feb 09, 2012 1:01 pm
Hello. Does anyone know how to solve this kind of problem? I have the same problem with my E45M1-I Deluxe and Windows 7 x64.
I will check movie codec ASAP (it is Avi file, that's everything I know ATM). I like Splash Pro. UI is nice and it is really easy to use. ATM I'm using trial version, but I'm not going to buy it unless it works :(
norfolk
PC Specification: Phenom X3 AMD HD5570 Win7 64Bits
Sun Apr 22, 2012 6:26 pm
I have the same problem with all kind of files; when forwarding file the app close with no error message.
