Im currently testing Splash Pro. The Motion² Feature is quite nice and so is the reliability of the Player to playback all Formats/File sizes that I use.
I do however have a Problem with the Color depth (Dont know if this is the correct term, my english isn't that good).
To see what I mean, here are two comparison Screenshots from VLC Player and Splash Pro (trial) from the Avatar 1080p trailer:
VLC:
Splash Pro:
This Effect is extremely strong when the image is fading-out or fading-in and is amplified when turning on the light boost Feature. It looks a little bit like the color depth is limited to 16bit. Until a recent patch for VLC I had the same Problem there (I think it had something to do with VLC being incompatible to x64 Systems or so). Is this Problem known and is there some way to fix it?
