Valk
PC Specification: Win7 HP x64, GTX570, intel i7-3820
Action vs. FRAPS (FPS Tests)
Fri Nov 23, 2012 10:10 pm
I recently saw Action! on Steam Greenlight.
I have been interested in a new game recorder for quite awhile now, mainly due to FRAPS having no compression/large file sizes. So when I saw Action! with it's claims of excellent performance vs. competitors while having excellent quality, I decided to try the trial out.
My Rig is this:
- Win7 x64 Home Premium
- GeForce GTX570
- intel i7-3820 3.60GHz
- 8GB RAM
- 2TB 7200RPM HDD (I know it sucks...) w/ 500GB partition dedicated to video storage
- ASUS P9X79 Mobo
My Results with Full FRAPS vs. Trial version of Action:
Sleeping Dogs @ Ultra/High Settings:
FRAPS: Stable 50-54FPS
Action: Unstable 40-50FPS
The WarZ (My primary recording game) @ Max Settings:
FRAPS: Stable 34-36FPS
Action: Stable 27-29FPS
COD: BOII MP @ Max Settings:
FRAPS: Locked 60FPS
Action: Stable 57-60FPS (Had an issue where it would cause a massive drop in FPS when done recording)
Darksiders II @ Max Settings:
FRAPS: Locked 60FPS
Action: Very Unstable 55FPS-62FPS (Was suppose to lock at 60FPS)
Dead Space 2 @ Max Settings:
FRAPS: Locked 30FPS
Action: Locked 30FPS (Once again caused massive drop in FPS when done recording)
What I mean by stable: FPS occasionally goes up/down and stays within the said FPS, no radical drops or increases.
What I mean by unstable: Consistently/Constantly changing FPS commonly going outside the said FPS, has radical changes.
What I mean by locked: Program/Game locks/limits the FPS to a defined value.
These were my results, so I can personally say that FRAPS has better performance then Action. Although; I highly prefer the Action! UI over FRAPS, and find it's options and file sizes far superior to FRAPS. As far as quality goes, I think both are outstanding.
I am still debating over using Action!(Excellent UI and smaller file sizes) over FRAPS(Better Performance). If I come to a conclusion I will be sure to post it here.
Thanks for reading,
Valk
Blutaar666
PC Specification: Phenom X4 955, Nvidia 570GTX, Win 7
Re: Action vs. FRAPS (FPS Tests)
Sat Nov 24, 2012 2:19 pm
I assume you did that without using your I7 at it's full potential. Mirillis is supporting Intel Quick Sync:
http://mirillis.com/en/products/tutoria ... s.html#top
I think you will gain alot with that.
And you should record to a seperate harddrive.
RuskiRozpierdalacz
PC Specification: q9550 gtx460 6gb W7HP 64bit
Sat Nov 24, 2012 6:13 pm
Blutaar, his CPU doesn't have GPU, so he can't use QuickSync.
Last edited by RuskiRozpierdalacz on Sun Nov 25, 2012 10:30 am, edited 1 time in total.
Premiere Pro, Action! user. I still believe that I can help someone on this forum.
Valk
Sat Nov 24, 2012 9:40 pm
Blutaar666 wrote:I assume you did that without using your I7 at it's full potential. Mirillis is supporting Intel Quick Sync:
Quick Sync is not applicable to me due to what Ruski said. Although, I wouldn't use it anyways due to MP4 having a far inferior quality to AVI.
Indeed I should record to a separate HDD, but until I get my hands on another I won't be able to.
Nevertheless; in it's current state without Quick Sync, Action! suffers lower performance than FRAPS. I even rechecked Darksiders II (due to me finding it's results odd), and this time it was even more unstable.
Blutaar666
Sat Nov 24, 2012 11:07 pm
AMD user her ;) Thought all the I7 have an IGPU. The performance "problems" are strange, all of my clan members have better performance (inlc. input lag) with mirillis. Anyways, thx for your test.
