vivan
Re: Splash Lite 1.3
Sun Feb 28, 2010 5:50 pm
3) After entering windowed mode - playlist resets to the beginning.
Also scrollbar dissapears:
4) I have one video file with HUGE bitrate. MPC-HC (using DXVA) playes it fine (ok, not fine - the player just hangs on so I can't pause or exit fullscreen... but it plays it without dropping frames).
1.3 drops much more frames (on fullscreen without showing info) - 1.2 playes this part better (with dropping frames, but only a few)...
But this is extreme Blu-Ray rip - most of then doesn't have such high-bitrate scenes.
Maybe new statistics (that is working even when not showing - am I right?) eats up last cpu cycles?
And some small suggestions:
- Playlist & settings windows have too bright line in the top, imho.
- When exiting from fullscreen mode - playlist window appears with aero effects. And atracts to much attention (when still looking at player)...
I think it's better to return how it was (if it's possible)
Hope this will help to make the best player ;)
P.s. Btw, I've finded information, why my ION netbook can't play 854x480 and 1024x576 with h/w acceleration:
All current third generation PureVideo hardware (G98, MCP77, MCP78, MCP79, MCP7A) cannot decode H.264 for the following horizontal resolutions: 769-784, 849-864, 929-944, 1009–1024, 1793–1808, 1873–1888, 1953–1968 and 2033-2048 pixel
So the reason was simple...
PS Vita, Nokia N8
toxi4en
PC Specification: X2@3800+, Asus M2N-E, Ati 2600XT, Win7
Re: Splash Lite 1.3
Wed Mar 03, 2010 12:09 am
Hi, all.
First of all I want to congratulate the team that's created this wonderful All-In-One (free of fee/haven't tried the other versions of Splash!/) player. Thanks a lot! Sorry for my bad English...
I've been searching for a long time to find a player with internal codecs capable of playing full HD videos with such ease (my CPU - AMD x2 3800+ loads for 5-10% at 1080p videos).
However I have a few suggestions for the future versions to add:
1. Overlay (VMR) subtitles display, so in non 16:9 format videos (16:10, 4:3, 5:4) the subtitles are displayed on the black bar below the video.
2. LFE output for 2.1/4.1/5.1 speakers configurations (all low freq mixed in the subwoofer channel).
3. Some basic OSD - volume in % at least.
4. And last, but not least... skin support, though I find the original skin of the player very good.
Thanks in advance... and keep up the good work. ;)
Imo
PC Specification: Q6600 3Ghz, ATI 4830 512M, Win7 HP x64
Re: Splash Lite 1.3
Wed Mar 03, 2010 3:14 pm
Crashes when I select the TUNER/TV tab in the Settings Menu.
I have a FireDTV S2 DVB Satellite Receiver (BDA Driver installed and working in DVBViewer).
Helios
Re: Splash Lite 1.3
Sat Mar 06, 2010 8:34 am
Hi Imo,
Imo wrote:Crashes when I select the TUNER/TV tab in the Settings Menu.
I understand it is a DVB-S tuner. Unfortunately we do not support DVB-S yet. TV tab should be blocked for Satelite tuners. It will be blocked untill DVB-S support is added.
Thank you for your feedback.
vivan
Re: Splash Lite 1.3
Sat Mar 06, 2010 12:40 pm
1) About AR. Also that problem (first one) happens with video with AR 16:9 e.g. 848x480 (16:9).
768/9*16 = 1365.(3) Rounded - 1365.
If I set display resolution to 1360x768 - then i have 3 pixel's strip - 1 from top, 2 from bottom.
1360/16*9 = 765.
If I set resolution to 1280x720 - everything is fine.
So, I think, that if display is 16:9, but not exact 16:9 (e.g. my 1366x768) - 16:9 video should be streched to it's resolution.
2) If I open video (only when using drag&drop):
D:/video/1.mkv
then trying to open
D:/2.mkv
- I get "Failed to open input file!!!" error.
folder/file name can be other.
Btw, if i open
D:/video/1.mkv
and then
D:/1.mkv
Splash opens first video (D:/video/1.mkv, when it should open D:/1.mkv) - without "Failed to open input file!!!" error.
3) if I close Spalsh (when playback is paused) - it plays audio for the short period of time (1/10 of a second) and then closes.
4) if in fullscreen mode I press 'o' (btw, menu says it should be "Ctrl+O" - is it a bug or a feature?) - "open file" dialog shows... but without mouse pointer. The same was about settings menu - but it was fixed.
5) when choosing any option with Enter (e.g. when using "open file") - playback mode is switched (between windowed and fullscreen modes).
PS Vita, Nokia N8
budzis
PC Specification: PC, XP
Re: Splash Lite 1.3
Sun Mar 07, 2010 7:28 pm
I've got error, when i go to Tuner/TV in settings:
Tuner error (dvb-t)
0x8007000e (0x00000370)
After that it's don't scan channels - Frequency:0kHz (B: 0 MHz)
Helios
Re: Splash Lite 1.3
Sun Mar 07, 2010 7:47 pm
Hi budzis
budzis wrote:I've got error, when i go to Tuner/TV in settings:
Tuner error (dvb-t)
Error means: OUT OF MEMORY, but in could be an effect of other error just before.
please provide more details about your hardware:
RAM memory, tuner model.
Please ensure no other software or servise uses your tuner while running Splash Lite.
Was it working on previous Splash Lite versions? (e.g. 1.2), because this part of Splash have been strongly developed recently.
thank you for your feedback and waiting for more details,
budzis
Re: Splash Lite 1.3
Mon Mar 08, 2010 6:15 am
Helios wrote:Hi budzis
Computer:
Pentium4 2.26G
RAM 768M
Win XP SP3
Tuner - Freeview usb dongle AF9005 BDA
Previously i had Splash Lite (1.2?), but the error wasn't. I uninstall SL 1.3 and install SL 1.2, but the error stays there.
pierrez
PC Specification: WinXP SP3, E6300 DualCore, ATI HD2400
Re: Splash Lite 1.3
Wed Mar 10, 2010 2:41 am
Hello Team,
just to report an issue with watching TV under Splash Lite 1.3 (have same pbm with previous version btw but using 1.3 now and was hoping it would resolve that issue).
Essentially I've been able to scan DVB-T here and find a few channels - however, when I try then to watch TV, Splash just crashes out right! No error code, no explanation, just the usual Windows crash notice.
My config: WinXP SP3, E6300 Dual-Core (not C2D :-]), 4GB DDR2, ATI HD2400, Terratec Cinergy T² DVB-T (USB2, BDA driver).
Note: HD decoding via DXVA works great (except for E-AC3 decoding but I've posted about this in another topic).
Thanx for any help you could offer. :)
makthedon
Re: Splash Lite 1.3
Wed Mar 10, 2010 8:44 am
Is it supposed to decode DTS HD MA audio? Because it does for me. The info in the player says it is DTS HD. Or is it only DTS core?
