tuvi123
"Please install Divx codec" error message
Sun Jul 31, 2011 1:56 pm
When I run the file I get "Please install DIvx codec" errror message (the audio played but no video)
I thought splash pro already have this codec built in.
here is the file info:
Code: Select all
General
Complete name                    : G:\Files\hells.kitchen.us.902.ws.pdtv.avi
Format                           : AVI
Format/Info                      : Audio Video Interleave
File size                        : 349 MiB
Duration                         : 43mn 0s
Overall bit rate                 : 1 135 Kbps
Writing application              : Lavf53.2.0
Video
Format                           : MPEG-4 Visual
Format profile                   : Advanced Simple@L5
Format settings, BVOP            : 2
Format settings, QPel            : No
Format settings, GMC             : No warppoints
Format settings, Matrix          : Default (H.263)
Codec ID                         : XVID
Codec ID/Hint                    : XviD
Duration                         : 43mn 0s
Bit rate                         : 998 Kbps
Width                            : 624 pixels
Height                           : 352 pixels
Display aspect ratio             : 16:9
Frame rate                       : 29.970 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Compression mode                 : Lossy
Bits/(Pixel*Frame)               : 0.152
Stream size                      : 307 MiB (88%)
Writing library                  : XviD 63
Audio
Format                           : MPEG Audio
Format version                   : Version 1
Format profile                   : Layer 3
Mode                             : Joint stereo
Mode extension                   : MS Stereo
Codec ID                         : 55
Codec ID/Hint                    : MP3
Duration                         : 43mn 0s
Bit rate mode                    : Variable
Bit rate                         : 123 Kbps
Channel(s)                       : 2 channels
Stream size                      : 38.0 MiB (11%)
Alignment                        : Aligned on interleaves
Interleave, duration             : 24 ms (0.72 video frame)
sigma
PC Specification: SU4100, Intel 4500 MHD onboard, Win7 x86
Re: "Please install Divx codec" error message
Wed Aug 10, 2011 11:09 am
Splash is a dedicated HD H264 player. Your avi file is encoded with xvid. Just install xvid codec to be able to see the video stream.
Thu Aug 11, 2011 12:22 am
Splash does not include divx/xvid codec.
It requires a codec to be installed.
