daniel44
help with intel quick sync, fake 2 displays
Fri Nov 30, 2012 2:38 pm
hi :)
i have a problem with intel quick sync that i would like you to help me with.
i had the quick sync to work with my computer and the videos are really good.
the problem with it is with the monitors.
my display has 2 connections, one is DVI and the second is VGA.
i connected the VGA to my intel HD Graphics card and followed the tutorial and the v sync was working.
now every time that i mooved my mouse to the right side of my monitor instead of stopping it just kept moving to the second monitor that i don't have so every time i need to move the mouse a lot until i can acually see and use the mouse cursor.
i made a video:
http://www.youtube.com/watch?v=pIPnMZ9X ... e=youtu.be
sorry for my bad grammar, english is not my first language.
please help!
vivan
Re: help with intel quick sync, fake 2 displays
Fri Nov 30, 2012 7:08 pm
Move second screen like this:
After this you will "lose" cursor only if you move it exactly to the upper right corner.
PS Vita, Nokia N8
