IzualNM
PC Specification: IntelAtomN455, 250 mb, windows 7 starter
help with the resolution of my action!
Thu Dec 06, 2012 6:25 pm
Hi I have a problem, what happens is that I wanted to record only part of the PC screen and happens to put a higher resolution for my screen and I can not shrink it because the edges of the screen pass, and tried to restore the factory settings but do not know how, and I need your help please D:
Re: help with the resolution of my action!
Sat Dec 08, 2012 11:10 pm
Did you mean that Active Desktop Region Mode panel is out of your resolution?
IzualNM
Sat Dec 08, 2012 11:50 pm
radi wrote:Did you mean that Active Desktop Region Mode panel is out of your resolution?
yes, i need help
Mon Dec 10, 2012 1:15 pm
Press "0" (zero) to restore Active Desktop Region to default size.
