teckiepc
PC Specification: Phenom 9500, ATI 4650HD Vista 32bit 4GB
Dolby True HD support on Splah Lite
Mon Mar 15, 2010 3:26 am
will it be available? or only found in Splash Pro?
If only found in Splash Pro, can it be made available ASAP :D
will definitely pay for it!
now for some off topic question.
can splash lite be made to install without administartor rights? (for installing in the office computer :twisted: )
is there a mac version? is it in the works? :?:
Re: Dolby True HD support on Splah Lite
Thu Mar 25, 2010 11:38 pm
TrueHD will not be available yet in first SPlash PRO versions.
We plan to develope full HD audio codecs support for Splash BD version.
The mac version is planned but development is not started yet.
We plan to start mac versions after we release Windows versions of our products.
You may try just to copy SplashLite.exe file from your primary PC and use it on other computers.
