rallen52
PC Specification: gateway/intel grahpics/win7 64 bit
crashes on tv buttom
Fri Dec 07, 2012 8:46 pm
i have tried this software numerous times and the watch tv never works,it crashes as soon as you hit the tv button,i m running a very common set up,a haupauge hvr 950q tv stick with win7 tv software on a win 7 64 bit machine,is there a fix for this,has anyone else had this problem,i ve have tried 4 different version of this software and no luck yet,any help would be much appreciated.
bozo
PC Specification: i7 2600k, GF GT240, Win7 x64
Re: crashes on tv buttom
Fri Feb 08, 2013 4:03 pm
I can confirm this error. I also mentioned about this error few versions ago. Unfortunately without reaction from dev side.
P.J
Wed Feb 20, 2013 5:14 pm
I have the same problem too :?
Fri Feb 22, 2013 4:28 pm
Thank you for your report. Someone from the tech lab will look into it. Please post as many information as you have.
P.J
Fri Feb 22, 2013 11:02 pm
What information do you want? Nothing could fix it.
Device: Gigabyte U8300
jeremstyle
PC Specification: Windows 8
Wed Mar 13, 2013 8:45 pm
Same problem with HDHomerun.
