deadspeak
PC Specification: intel core i3 530, win 7 ultimate 64bit,
mediacenter remote
Thu Aug 11, 2011 11:12 pm
Hi
I'm testing the latest version of splashpro, and i love it, the only thing that is stopping from buying is that i am unable to control it with my mediacenter remote
I'm using a Fractal Design Shape HTPC Remote Control http://www.quietpc.com/gb-en-gbp/produc ... /fd-remote
I know the remote simulates keyboard shortcuts in order to control, i can use other players like mediacenter classic etc.
Hope you can help
Thanks
Paul
djs
PC Specification: i7 860, Gforce 560ti, Win7 x64
Re: mediacenter remote
Tue Aug 16, 2011 12:16 pm
I've got the same remote and can't get it to operate with Splash Pro either.
On my HTPC with iMon Remote all I can do is Stop and Pause.
Has anyone info on how to set up remotes to work properly with Splash Pro please ?
deadspeak
Tue Aug 16, 2011 6:33 pm
i've got a hauppauge remote on the way this week so i'll test with that as well.
I really want to give these guys my money, i've had it setup as external player with mymovies and it works fantastic, but without a working remote the WAF is zero, so i can't justify dropping the cash.
Cheers
Paul
ocd
Wed Aug 17, 2011 3:14 am
Same Problem here. I have an HP HDX18 1180CA Media/Gaming Laptop which I connect to the big screen via HDMI. This laptop comes with the HP Media Center Remote and I can only Play/Pause and Stop. No Rewind/Forward, nothing else works.
P.J
Thu Aug 18, 2011 6:40 am
There are some programs that let you define hotkeys.
deadspeak
Thu Aug 18, 2011 6:46 am
Thanks, i've tried several, intelliremote does'nt support my remote, event ghost, i'm having difficulty setting up. I should be integrated into the player, i want as little software installed on my htpc as possible.
djs
Thu Aug 18, 2011 12:26 pm
Event Ghost should work, but it's beyond me to get it set up.
There doesn't seem to be a sensible and easy to follow instructions anywhere, lots written about how good it is and instructions that are supposed to show how to get it to work, but I can't follow them !
Anyone here got a 'how to' for it please ?
deadspeak
Tue Aug 23, 2011 7:32 pm
Just tested out with a new hauppauge mce remote, and all works fine.
In summery if your using a remote that simulates keystrokes rather than a full fledged MCE remote then you may well have problems.
Thu Sep 15, 2011 9:23 pm
deadspeak wrote:Just tested out with a new hauppauge mce remote, and all works fine.
Thank you for this feedback. We will try to investigate problem with remotes.
